Old     (kenteck)      Join Date: Jan 2005       04-19-2011, 10:30 AM Reply
Has anyone ever fixed a loose tilt steering column in a boat?
Old     (snyderm)      Join Date: Aug 2010       04-20-2011, 12:28 PM Reply
I would like to know the same. I have the tilt steering. and its a little loose.
But the main thing is when I have weight in the boat. and accelerate. I can hear a rattleing noise in the dash. but the wheel doesnt shake.
My rudder is tight.
Old     (bbeach)      Join Date: Jul 2002       04-21-2011, 8:48 AM Reply
If your wheel has a center cap, remove it gently with a standard screwdriver (should pop out)... Underneath that is a big nut, remove that... Inside the column there are either 2 allen head bolts that can tightened OR two nylon threaded nuts of varying sizes OR there's a grease zerk (if so grease it). Put steering wheel and center cap back on...
Note: this is how i've done it on mastercrafts and malibu's...
