I said 20w-40 but ment to say 25w-40 in my earlier post Jason said 20w-40 and I just had that stuck in my head. Mercury marine changed the recommended engine oil to 25w-40. As I stated above Mercury is about the only company that I know of that makes this combo of multi-weight oil. AtTheLake would not recommend a 10w-40 if you plan on starting it in the winter a 10w is too thin to form a proper film and protect your engine. Walter does not specify non-detergent 30w but if you can find it localy than use it.
Direct from Mercury Marine
Engine Oil
To help obtain optimum engine performance and to provide maximum protection, we strongly recommend the use of the following oils listed in the order of recommendation:
1.MerCruiser / Quicksilver Synthetic Blend, NMMA FC-W rated, 4 cycle oil.
2.MerCruiser / Quicksilver 25W40 NMMA FC-W rated oil.
3.A NMMA FC-W rated oil.
4.MerCruiser / Quicksilver 4-cycle 25W40, non FC-W rated oil.
5.A good grade straight weight detergent automotive oil per the operating chart below.
NOTE: The use of non-detergent oils, multi-viscosity oils (other than as specified), non-FC-W rated synthetic oils, low quality oils or oils that contain solid additives are specifically not recommended.
This crankcase oil recommendation supersedes all previously printed crankcase oil recommendations for MerCruiser gasoline engines. The reason for this change is to include the newer engine oils that are now available in the recommendation.
Older owner manuals, service manuals and other publications that are not regularly updated will not be revised to show this latest engine oil recommendation. Current owners manuals, service manuals and other service publications that receive regular updates will receive this revised recommendation the next time they are updated. (Message edited by yubasanger on October 08, 2008)
