I think this should work, Bob. One issue I can see happening is the pressure pumping water from the locker sack (or tank in my case) to the bow sack might blow the hose off the fittings at either end. Using a hose clamp on a tank shouldn't be a problem. But how could you secure the hose to a screw on sack fitting? Is it secure enough? Or would a hose clamp work in this case too? Also, positioning the bow sack so the fitting was at the bottom will be necessary for it to drain downhill.
