Old     (hillbilly)      Join Date: Aug 2002       05-08-2003, 1:46 PM Reply
What would sound better for all types of music.Going to put 1 sub under the bow in a closed port box,What do you guys think sounds best for all types of music?......Thanks JEFF
Old     (typhoon)      Join Date: Jul 2001       05-08-2003, 1:48 PM Reply
definately 1 12
Old    mbsteve            05-08-2003, 2:45 PM Reply
dont waste your time on a single ten.
Old     (bob)      Join Date: Feb 2001       05-11-2003, 10:50 PM Reply
Ive got a ten and have plans for a 12 in a ported enclosure if that means anything to you. Dont skimp on power to drive it either or you might as well get the ten.
Old    whitechocolate            05-12-2003, 6:41 AM Reply
Go with This Sub
Old    whitechocolate            05-12-2003, 6:42 AM Reply
Go with This Sub
Old    cws_kahuna            05-12-2003, 10:22 AM Reply
I run a single ten and it sounds fine. I just have always liked 10s over 12s if you are playing all types of music. I think either will sound good though, what kind of amp do you plan to use to run the sub?
Old     (hillbilly)      Join Date: Aug 2002       05-12-2003, 1:58 PM Reply
Thinking about a JL 500/1 or something close to that.I want a seperate Bass control for just the sub.Think 500 watts is enough?It will be going in an 86 nautique under the closed bow area.
Old     (h20jnky)      Join Date: Mar 2003       05-12-2003, 7:37 PM Reply
one of each.......!
Old     (kingpin)      Join Date: May 2003       05-24-2003, 8:04 AM Reply
It all depends on what kind of sound you want. If you are looking for a tight clean bass sound go with a 10, but if you want to feel it thump more get a 12. Whatever you do go with JL. There subs can be a little pricey at times, but well worth the money. The best single sub to go with is the 10W7 or 12W7. I would pair the JL subs with the JL amps. This is my $0.02 not knowing what the budget is or how much room you have in the boat. Whatever you do go with JL subs. I cannot stress that enough. The quality is bar none and the subs range in price from 125-700.
Old     (ryanbush11)      Join Date: May 2003       05-24-2003, 11:02 AM Reply
a 10 or 12 W7 is way too heave to put where he wants, that would need alot of support, and alot more than 500 watts, i have a rockford forgate he12 in my x star and it sounds awesome
Old     (kingpin)      Join Date: May 2003       05-24-2003, 2:59 PM Reply
What support would he need you build the box and install it. you could run a JL 500/1. JL says it is rated at 500, but real output is about 700. The JL amps are the best out there. Not trying to talk sH@t, onece again this is my opinion.
(Message edited by kingpin on May 24, 2003)
Old     (htown)      Join Date: Jan 2003       05-24-2003, 9:24 PM Reply
Holy sub in the CRX is bound to be worth more than the car.
Old     (ryanbush11)      Join Date: May 2003       05-25-2003, 6:56 AM Reply
the sub ways close to 70lbs and is a very strong sub, you have to build a very strong box for one, we were running 2 12w7s with 2 phoenix gold 1400 watt amps and the subs were locking up because of lack of power
Old     (kingpin)      Join Date: May 2003       05-25-2003, 7:28 AM Reply
No offense but I would not compare the quality of the jl amp power and Pheonix Gold. I am saying this from personal experience. I promise if you go into a shop and get them to demo the 500/1 on either 12w7 or 10w7 it will be the shizl.
Again this is my own opinion.
Stereos are like everything else. It comes down to personal opinion. What I like you may not like, what I think sounds great you may think is not enough bass/too much bass. Just go and listen to the stuff yourself at a stereo store that you can trust. Go to several and see what they all say. DEMO,DEMO,DEMO. Research, Research, Research.
As Long as you like the stereo that is all that matters.
Jeff,
By the way check out the w6v2 ProWedge Systems, and W7 ProWedge Systems. I know where you can get a JL 10w7 with the box for 500. Let me know if you are interested.
