just starting to get them dialed and was wondering if there is a clearly better board for air trick. riding a 08 one but haven't tried anything else on cable air tricks
i ride cable quite often.. i have a ronix mana.. holds super tight.. also alot of the cable guys ride hyperlite eras... of lf witness.. and sorry.. you must be high.. never seen one guy do an air trick on a SS.. alot out there doin presses and hittin booters.. never loads.. hope this helps
There is about 7 different Liquid force boards that are perfect for cable. For air tricks u want a fast board & something that holds a good edge. Ive owned over 50 boards and my favourite is between the witness & the new S4,also the ps3 substance. The witness holds a great edge & is very fast but u can still slide it around & LF doesnt put ugly big fins like other board companys put on there boards that catch on everything when u wanna go sideways or on rails.
i really like the new jstar lidberg board for air tricks. next to that id say the LF witness is probably one of the best shapes for the cable all around (especially air tricks).
yes...Josh Wright throws down huge difficult air tricks on a SS. I did a few air tricks on a SS, but it takes some getting used to.
My favorite board for cable is the LF Shane. Tracking and speed to me, are most important for throwing huge air tricks...the shane has both. Also binding play a factor. Since you're laying down on a hard edge you want bindings with no toe lift to achieve the hardest cut possible. I found the SS D2's to be the best.
I loved the liquid force trip, It's a fairly loose board but it holds tight enough and the shape is just straight up awesome and has probably the smoothest fastest ride of any board out there.
