Below you can see my crappy diagram.
If I have a pump, pumping through a y splitter to two fat sac with equal length hosing going to each sac. Both fat sacs should receive water at an equal rate. The key here is that one sac is bigger than the other.
Once the 400lb fat sac is full what will happen?
A. Water will go out the vent hose, and at the same time the other half of the water will continue filling up the 500lb fat sac.
B. Water will stop going into the 400lb sac and all of the water will go into the un-full 500lb sac untill it is full.
If A. is what will happen, then, when the water goes down the vent hose and reaches the Y splitter, will it:
C: Go to the one way valve and out of the boat.
D: Instead of pushing the one way valve open, will it go down the vent hose of the 500lb fac sac and assist filling it up.
At some point will both sacs be full and both have water going through the one way valve and out of the boat?
Finally, when reversing the pump since it will be a closed system, when the smaller 400lb sac is empty will the pump be able to continue emptying the 500lb sac? I would assume so.
