Old     (xxxChrisBxxx)      Join Date: Jun 2010       06-18-2010, 6:00 PM Reply
I am building a amp rack on the inside wall of my boat and would like to epoxy the rack to hold it in place. When I peeled the carpet back I found that the inside part of the hull is coated with spray foam. Will epozy react with the spray foam? Should I remove the spray foam? The boards that will be epoxyed will not hold much weight. The main support was screwed into a support at the rub rail line.
Thanks in advance for any advice that you may have.
Old     (rallyart)      Join Date: Nov 2006       06-19-2010, 7:25 PM Reply
The foam is there for flotation and is weak. You need to remove it from the area you wish to epoxy.
