I did it very easily and inexpensively on my 2001 calabria. Go to westmarine.com or some other marine suply store and get a perko battery selecto switch. You hook the grounds of the two batteries together and hook your boat ground wire up to one of the batteries. The the positive of each battery goes to its own terminal on the switch. There is another terminal that the boat posistive hooks up to. The swith has OFF,1,2,ALL. This allow you to run off of bat 1 , bat 2, or both. It also allow you to disconnet both batteries with the turn of the switch. When running my boat, i set the switch to all and let both batteries charge. When we stopped to relax I switched to 2 and used the stereo. If 2 went dead that was OK because I alway had 1 to start the boat with, except for the day i got the bright idea to switch to 1 and continue playing the stereo. Anyhow that is probably the simplest and cheapest method. You can put the automatic isolators in for a few extra bucks. I also used 4 gauge audio power wires for all my connections becasue it is flexible and much more easy to work with than battery wire. Hope that helps
