I need a replacement ballast bladder (the cover is fine) for my factory plumbed X-9. It is the bag under the rear bench seat. I can get it from MC but it is big $. I know somebody else makes them or can make them. It has three inlet/outlet elbow connector fittings for the quick connectors. I also need a section of the flex hose from the pump to the bag. Any ideas would be appreciated.
I saw those. My only concern is I have two fittings on one side high on the bag end and one on the other end low. It didn't look like the Pro X where the same setup. They have one on top and the others match. Will it still work the same. I also saw that they can custom make the bags. Do I need that or is the standard bag the same?
the custom fly high sacs are pretty expensive. soudns liek your trying to save some coin. If so just find the closest size bag yu can , it will be muhc cheaper. Fly high sacs have three openings, a fill/drain/vent.
