Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through August 20, 2009
Old    thebiggmann            08-10-2009, 8:01 AM Reply
I'm looking at buYing another 750 and I wAs wondering if the pro x series sac has the water bed fitting like my launch pad one. I didn't see anything about it on the sites I was on, but I'm at work and on my iPod sothat probly doesn't count for much. Sorry if it's out there somewhere else
Old     (absoluteboarder)      Join Date: Aug 2002       08-10-2009, 8:35 AM Reply
...from what i have seen they come with quick connect hardware to fit their connector system. You can get them with just a cap so you can fill them with a pump. they will have a thread but i think its smaller than the water bed thread. someone correct me if i am wrong. you have to ask for which fitting you want
(Message edited by absoluteboarder on August 10, 2009)
Old     (tuneman)      Join Date: Mar 2002       08-10-2009, 10:43 AM Reply
Time to upgrade. Get the fittings that best fit the Fly High and then adapt to your old launch pad. Here's an adapter:
http://wakeskishop.com/index.php?main_page=product_info&cPath=4_13&produc ts_id=62
Old    thebiggmann            08-10-2009, 11:38 AM Reply
Dude that's what I use. I built my own pump from an attwood tsunami pump and use a water bed fitting just like that. So I'm assuming I'm good then
Old     (spencerwm)      Join Date: Feb 2009       08-10-2009, 12:05 PM Reply
Biggs,
As long as you have the male twist connect fitting on the end of your pump and tubing you should be good to go. Sounds like you probably are. If not there are fittings to make it all work.
spencer@wakemakers.com
