You almost can't go wrong with weighting that boat. You're on the right track. Just make sure you add to the front to harden the wake a little. Too much in the back makes the wake tall and thin. Then it begins to break. Including stock ballast, I run about 450 on each side of the motor, 1200 in the walkthrough and nose, and a few hundred scattered around the middle of the seating area. Consider some lead. It makes life much easier.
