Old     (rvh3)      Join Date: Jul 2003       04-26-2009, 6:54 PM Reply
Anyone have problems with the sensors that drop down into the hard tanks?
Old     (sinkoumn)      Join Date: Jan 2007       04-26-2009, 7:48 PM Reply
Specifically what type of problems? Are the floats sticking on the way down/up, or are you getting intermittent signals with with gauges?
Old     (rvh3)      Join Date: Jul 2003       04-26-2009, 9:08 PM Reply
Gauges getting funky readings. Floats seem OK
(Message edited by rvh3 on April 26, 2009)
Old     (sinkoumn)      Join Date: Jan 2007       04-26-2009, 9:26 PM Reply
Any corrosion on the wires - build up or rust on either connecting end?
All that I have seen is either from the floats getting stuck, or the wire connecting the sender on the tanks to the gauge has basically corroded/crapped out.
(Message edited by sinkoumn on April 26, 2009)
Old     (rvh3)      Join Date: Jul 2003       04-26-2009, 9:55 PM Reply
I'll check, Thanks.
Old     (bmh2208)      Join Date: Apr 2004       04-27-2009, 7:19 AM Reply
I have a similar problem. I took the tank out and then the sensor. There is a clear plastic tube that covers the PCA. On it there are a ton of reed switches that react to the float. On mine, the board was completely corroded. The way that it works, is that the reed switches close the circuit. Depending on how far down the chain it is, the resistance changes. If the corrosion has taken out some of the resistors and/or switches, the gauge will read wrong. I think they were about $60 from the dealers. I tried to clean mine to fix it. It helped it work for about a second. Gotta order a new one.
Here is a pic.
Go to this thread about 2/3rds of the way down to see some more pictures.
http://planetnautique.com/index.php?name=PNphpBB2&file=viewtopic&t=13507&pos tdays=0&postorder=asc
Old     (trace)      Join Date: Feb 2002       04-27-2009, 7:20 PM Reply
Wow, that is a STUPID sender design IMO.
Old     (rvh3)      Join Date: Jul 2003       04-27-2009, 8:10 PM Reply
From Brandons thread, if you want to purchase a new sensor:
http://www.wemausa.com/tank_sensors/tank_level_sensors.htm#Fuel_Water_Tank_Sensors
Old     (trace)      Join Date: Feb 2002       04-27-2009, 8:20 PM Reply
It looks like all the plastic & aluminum housing sensors on that page are now superceded by a stainless housing version.
