Josh, your dealer should have calibrated your ballast on your x2 before it even left the lot, if they did not calibrate it, take it back to them and they *should know how to calibrate them, it usually takes a couple of fills and emptys, usually around 5 or 6, before the calibration is exact, but the reason your gauges are off is definitly because of them not being calibrated, call your dealer and you should be set..
