hey derrick,
i completely understand the desire to make something different and artistic as well as a document of someone riding, and i appreciate you trying to do so.
so to help out folks like me (if there
are any others like me - i imagine jrod cringing right about now
), it would help if:
- the images somehow complimented each other, either thematically or visually. if a filmmaker is using effects just because, it shows. like every other device in visual media, if used for it's own sake it's usually not interesting.
if you're young enough to remember when morphing technology first came out - it was used in everything just because it was hot. there was often no reason for it other than the creator wanted to use the latest coolest technology. nowadays, unless it produces an emotional reaction in us, its boring.
- the images were more discernable from each other. usually in a blend one image plays supporting player to the other (and thus it helps if there's a reason the two shots are being shown together).
- there was only movement in one of the shots. movement in both is more chaotic and makes it harder to figure out what either image is (especially if they're evenly present).
so for instance, with the oven/sbend shot, if the oven shot had started closer on the flames and only moved a bit if at all, and you'd had the sbend clip weighted a bit more (less transparency on its side), or if you'd cranked up the contrast on it so it's edges were easier to pick out, then we might have associated the heat/flames with his riding/passion, etc. chessy yes, but you get the basic idea.
another way to use it might be to take static shots of the tsr signs or location and use that as a backdrop in the blend. that way the actual riding shot is more prominent, but we also get more information about where all this is taking place. static visual information is easy for us to assimlate quickly, thus allowing us to see both images, but also focus more predominantly on the action. i could imagine an overhead birds-eye-view of the layout of tsr blended behind the shot of a trick. that might look pretty cool.
one way of thinking about blends might be this - if the blend would look good as a poster or ad, then it should work. if you think about movie posters or picture ads with multiple images, usually one image is more prominent, with the others supporting, either framing or just providing more context. the images are usually
layered, representing a foreground/background hierarchy.
anyway, excellent work. its good to see you're confident enough in your creative ability to solicit comments. best of luck in future endeavors!
