No, you cannot just screw threw the the driver's side wall on the walkway. Either mount it under the dash where the rest of your gauges controls are mounted, or through-bolt it onto the walkthrough wall. I would recommend installing it with the connectors facing down, as the circuit board is not marinized, and that will allow for water to drain out of the bottom if it should happen to get wet.
