Old     (canucked)      Join Date: Jun 2007       05-29-2008, 2:45 PM Reply
I need to change the rear bilge pump as well as the rear ballast drain pump. How do I get to it? I assume it is under the rear ballast tank which looks to be impossible to remove. Do you have to take out the fuel tank?? That sounds kind of stupid.
Its an 01 Air Direct Drive (sport)
Old    K.B.C.            05-29-2008, 2:59 PM Reply
not sure, but you'll definitely be able to get the answer at planetnautique.com
Old     (grant_west)      Join Date: Jun 2005       05-29-2008, 3:22 PM Reply
Its quite a job. Remove the sear seat. Disconnect the Gas tank. Scoot it forward. This will allow you to take out the rear ballast tank. Then getting to the rear bilge pump is easy access
Old     (canucked)      Join Date: Jun 2007       05-29-2008, 3:26 PM Reply
crap, I suspected as much
Thanks G
