I have been out on a 1977 SN and 1984 and 1989 SN2001's. The pre-2001 SN's have narrower beams which yields a narrow wake and the wake is much more abrupt and very little transition on the other side. The SN2001 has a wider beam which yields a wider wake (albeit narrower than most modern wakeboats) and the wake is shaped very nicely. They respond well to weight and the wake just gets bigger and cleaner. The wake is still more vert than the ramp of a Malibu, but it is not as abrupt and has a nicer transition than the pre-2001 Nautiques. If it were up to me and I had the choice between the two, I would easily pick the SN2001. I am hoping to pick one up as a project boat at some point in time. Hope that helps.
