Neither. Here's your options. You could put sacs in the V-drive compartment AND a sac in the bow. You could put a single sac in the walkway to the bow. You could get about 600 or whatever pounds in lead and disperse that around the boat. If you just put sacs in the back, your wake will curl over and get all mushy, and the boat would be difficult to plane. You need to compensate for forward/back ratio. The only way you could get away with one sac would be the walkway because it is in the middle/front of the boat, and would not throw off the balance since most people sit in the cockpit.
