Old     (lfadam)      Join Date: Nov 2008       05-03-2012, 8:37 AM Reply
Are inboard rear drain plugs standardized? It appears some fisherman down at the marina stole ours. Im hoping I can find one at a Marina or Lowes since Im about to go out to the lake.
Thanks
Old     (rallyart)      Join Date: Nov 2006       05-03-2012, 9:18 AM Reply
Mine is the same as my 1980 boat was and I could get it anywhere.
Old     (Sethjoe)      Join Date: Apr 2011       05-03-2012, 9:21 AM Reply
1/2" is the standard drain plug size.
Old     (tyler97217)      Join Date: Aug 2004       05-03-2012, 9:46 AM Reply
I think there are two sizes. I know I have had boats that the standard plug does not fit. I want to say that MC or Malibu use something different, but I might be wrong on that so don't quote me. I would call your dealer.
Old     (wdr)      Join Date: Dec 2011       05-03-2012, 9:58 AM Reply
My '06 Moomba and my '10 Malibu LSV both had/have stamped "1/2" NPT plugs. I have mine permanently attached now. I drilled a hole in the plug, soldered in a 6" piece of coated solid copper electrical wire and soldered on an eye ring onto the other end. I put it through the hull and secure it with a key ring loop into the eye ring to keep the "honest people honest". Pull it out and it hangs w/o any flopping around or banging on the hull.
Old     (shawndoggy)      Join Date: Nov 2009       05-03-2012, 10:17 AM Reply
MB uses a bigger plug. 3/4"?
Old     (lfadam)      Join Date: Nov 2008       05-03-2012, 3:53 PM Reply
Turns out it was indeed the 1/2 inch. Thanks
Old     (baitkiller)      Join Date: Jan 2010       05-03-2012, 4:54 PM Reply
How do you know it was a fisherman?
More obvious follow-up rhetorical questions held.
Glad you have a drain plug now.
