Hey Does Anyone Have Any Ideas They Want To Give Away For Some Billet Boat Parts. You Give Me The Idea And I Will Give You One Of My Prototypes. I Have All The Resources To Make Just About Anything.
I got a good idea for the mirror mount, I'll send you an email tomorrow when I can diagram it for you. We'll put on each of our boats, posts some pics and you'll see a lot of interest.
Weather looks good Thursday thru Sunday for some riding.
Here are a couple I sent to you touched up showing how it can go up or down depending on how you want the look. It would be very easy to change the design of the cut outs if something else was prefered. up
Solidworks, still not the greatest at it yet because I don't use it a whole lot. Mostly for seeing how productions machines designs will work. I did design a new swivel rack mount though.
Here Is One I Spent About 20 Minutes On. This Morning Using Your Idea Of A S Shaped Bracket. I Am Going To Redesign It And Post Some More Pictures. Make Comments At Will!!
Looks nice, would be cool if you could have different things machined into the straight section that is not all the way through, such as Mastercraft, Air(Natique), Malibu or Pimpist.
That Is The Intention For The Flat Area. My First Image Will Have A 3-D Tige Machined In It. I Plan On Changing The Complete Design. I Have Another Idea. I Will Post It When Its Finished.
That Is The Bling Indeed. Do The Screens Bounce Around In Chop? How About A Bracket That Extends All The Way Aross From One Pole To Another. This Would Be A Three Piece Assembly. When You Wanted To Walk Through To The Bow, You Could Swing The Middle Section Away. Simular To How You Window Swings Away.
The mirror needs to rotate on three axis', Not only right/left and up/down. Because of the odd angles of the tower it must also rotate so that it stays level with the horizon (if that makes sense).
