Old     (durty_curt)      Join Date: Apr 2008       06-30-2012, 10:22 AM Reply
I'm planning on buying a new amp for my new in boat setup.
4 WetSounds xs 650 speakers (aka 2 pairs) rms 100 Watts peak 200 Watts
And ONE kicker solo baric L7 8" DVC 2 OHM RMS 450 Watts peak 900 Watts
I was thinking of going with the WetSounds Syn 6 to power all this but wasn't sure if that would be over kill. What would you guys recommend?
Old     (chpthril)      Join Date: Oct 2007       06-30-2012, 11:03 AM Reply
The Syn-6 would not be overkill at all. I would also consider a Wet Sounds Class-D HT-4 (110W rms x 4 @ 4ohm) for the in-boats and an HT-2 (575w rms x 1 @ 4) for the sub. This would be a tad more to the in-boats and about the same for the sub. Or, the Kicker Class-D IX500.4 (75W rms x 4 @ 4 ohm) for the in-boats and the IX500.2 (500w rms x 1 @ 4 ohm) for the sub. Theres probably half a dozen other hi-efficiant amp options out there as well, these are just a couple that came to mind.
Old     (durty_curt)      Join Date: Apr 2008       06-30-2012, 5:41 PM Reply
wow thx for that info! Rather than using two amps to do the job, is there one amp that could do the job of two? (thats why i was leaning towards the syn 6)
Old     (chpthril)      Join Date: Oct 2007       06-30-2012, 5:54 PM Reply
Syn-4 = 100W rms to each XS-650 and 400W rms to your sub.
Old     (durty_curt)      Join Date: Apr 2008       06-30-2012, 6:38 PM Reply
what would be a good configuration if i did go syn 6?
Old     (chpthril)      Join Date: Oct 2007       06-30-2012, 7:00 PM Reply
Syn-6 = each in-boat on its own chnl using 1-4. Sub coils wired in series and then bridged on chnls 5/6
Syn-4 = Port side pair in-boats wired in parallel on chnl 1, stbd side pair in-boats wired in parallel on chnl 2. Sub wired in series and bridged on chnls 3/4.
Old     (durty_curt)      Join Date: Apr 2008       06-30-2012, 7:42 PM Reply
Your knowledge is well respected and appreciated! Thank you for the input and help Tigé Mike! I think i may stay with the Syn 6
