Old     (silverfish)      Join Date: Apr 2012       08-21-2012, 10:06 PM Reply
Which would have a better wake for surfing? Both 2008 models. Or what other boat would you guys recommend for surfing? Wanting to stay between $30-$35K and try to stay 2008 or newer. Only water sport I care about is wake surfing. I've found good deals on the two mentioned boats but want to get a good surf boat. Any help or info is appreciated.
Old     (rallyart)      Join Date: Nov 2006       08-21-2012, 10:13 PM Reply
215. The reasons I would pick it are due to hull design. The Falcon has a flatter bottom than the highly regarded Avalanche or the 215. The 215 will work well on both sides. However, others have are much better surfers than me so listen to them. If you can test drive the boats you will notice a difference. In my opinion the V215 is the best handling rear engine boat out there.
Old     (lakesurfer)      Join Date: Jul 2009       08-22-2012, 5:33 AM Reply
If you are into just surfing, then the 215. If you are into wakeboarding/surfing and a little skiing, then the Falcon. The Falcon will feel much bigger than the 215 because it has a 102" beam (compared to 96" beam on 215)
Also, if you spend a little more, you could pick up an 07 Avy/Tige 22Ve for around $35-$37K. You would get a lot more room and the surf/wakeboard wake would be great.
Old     (silverfish)      Join Date: Apr 2012       08-22-2012, 5:49 AM Reply
Yes I like the Avalanches and Tige 22VE also. It's a little harder to find one of those in my price range though unless I drop back to a 2006 or so. If I could find a 2007 or 2008 for $35-37K like you mentioned I would definitely be interested. I had read that the Falcon was a good all around boat but suffered a little on the surf wake. Is it going to be a noticeable difference? I'm no expert at surfing by any stretch but I want to progress in it. If the difference is really minor then it's no big deal but if its going to be a major noticeable difference then I want to stay away from it.
Old     (lakesurfer)      Join Date: Jul 2009       08-22-2012, 6:06 AM Reply
If you are really into surfing and you would like the room, the Avy/Ve would be my choice. I really think if you take your time, you can pick up a 2007 Avy for $35-$37K, especially now that summer is ending. My buddy just listed his 07 Avy for $40K and he may be willing to take less
https://www.onlyinboards.com/Details.aspx?ID=34592
Note: I really like the Sanger boats, but I am not a big fan of the 215. It seems to have a solid wave, but it is small inside and the freeboard is low. Just my 2 cents. You may want to see if you can find a Sanger 230 (or whatever it is called).
Old     (silverfish)      Join Date: Apr 2012       08-22-2012, 6:17 AM Reply
Thanks for the lead. I will take a look at this boat for sure. Looks like it is surf ready without me having to buy extra ballast bags.
Old     (silverfish)      Join Date: Apr 2012       08-22-2012, 6:33 AM Reply
So did the hull change on the Avy's in 2007? By looking at specs it looks like a 2006 weighs 3200# where a 2007 weighs 4000# so I'm assuming they changed the hull for 2007. Does this make a big difference in the surf wake from the 06 to the 07 models?
Old     (lakesurfer)      Join Date: Jul 2009       08-22-2012, 7:04 AM Reply
I am very sure the Avy 05-2012 hull is the same. I would not put much stock in the weight listed, centurion changes it each year even though the boat is the same. The 2006-2008 should be relatively the same boat. In 2009, they went with PCM engine, upgraded interior and different prop rotation (no impact on surf wave but seemed to help clean up wakeboard wake). If you back to 2005, make sure you get one with 330hp engine, not the 315hp engine. Also, the Avy comes in C4 (which is wrap around seating) or non C4 (which does not have wrap around seating and has a walk-thru on stbd back locker). I would highly recommend the C4 version (more seating and deeper stbd locker).
Note: I had on 08 Avy for 3 years. Great boat. My buddy's 07 Avy is identical accept for color.
Old     (silverfish)      Join Date: Apr 2012       08-22-2012, 7:10 AM Reply
Thanks for that info! Do you know much about the Falcon V? Will the surf wake on it be that much worse where I would notice the difference?
Old     (lakesurfer)      Join Date: Jul 2009       08-22-2012, 7:17 AM Reply
The Falcon is a 3 sport boat. It will wakeboard/surf/ski good but not great. The Avy is a world class/top 5 surf wave (of any boat on mkt) and a very good wakeboard wake. You would not have much fun skiing on it. There will be a fairly big difference in size/push of surf wave. The Avy will also have a much better rough water ride because of the Deep V hull. The only way the Falcon will come close to Avy surf wave is if it has the Switch Blade on it.
Go to WWW.centurioncrew.com and get a lot of your questions answered.
Old     (boardjnky4)      Join Date: Dec 2011       08-22-2012, 8:06 AM Reply
I ride behind a falcon frequently. I'm not a huge fan.
Old     (silverfish)      Join Date: Apr 2012       08-25-2012, 9:54 AM Reply
Ended up buying a 2008 Centurion Avalanche C4. Love it! It is lakesurfer's old boat.
