All these tips are good, but try a different kind of cut. Make sure it is progessive, but instead of keeping your knees real bent, and body down low, stay up! Stand up on your cut so that your hips are right into the handle. Give it a good pelvic thrust. If you have ever windsurfed, its like gettin into the harness, thurst your hips up and keep them forward. When I was learning raleys, this helped me a TON! My raleys used to be about 2 feet off the water, and everynow and then catching my edge, now I can float them out no problem. Try practicing cutting out on your heels beside the boat with your hips up, just so you can get the feel for it. It feels wacked, but try it!
