I've run Redline in limited slip automotive differentials and have tried it in engines. I normally use Mobil 1. They make gear oil, engine oil, and ATF that should be compatible with boat transmissions. Just use the type and weight specified by the transmission manufacturer. I don't suspect you'll have any problems because there is nothing that should be affected by a high humidity environment.
