Old     (dicky_diehl)      Join Date: May 2007       05-30-2007, 1:46 PM Reply
so what setup are you guys running for weight and speed.i am running 2 750's in the back the 1200 pound center bag which is maybe 900-1000 when full and my old 250's out of my 02 mobius under the front seats plus i am going to add some lead up front 300-500 pounds speed 23 wakeplate 100-75%up
Old     (acurtis_ttu)      Join Date: May 2004       05-30-2007, 1:57 PM Reply
Did you re-prop? How much can you fill the 750's in the rear?
Old     (ryan27r)      Join Date: Oct 2006       05-30-2007, 2:10 PM Reply
The 22 I ride in at times has 1200 in the bow and 750's in the rear. We put a bow sack in one day and the wake gained a ton of mass. It's just a pita to fill it.
Old     (dicky_diehl)      Join Date: May 2007       05-30-2007, 2:48 PM Reply
yes i got the wakeboard prop when i ordered the boat gets up on a plane just fine.the 750's fill all the way up plus some.they almost fill the hole rear compartment. hey ryan which bow sack did you use and do you think that you can fit the integrated bow sack under the seats.
Old     (ralph)      Join Date: Apr 2002       05-30-2007, 3:02 PM Reply
Wake must be pretty fat with that setup, got any pics?
Old     (ryan27r)      Join Date: Oct 2006       05-30-2007, 3:16 PM Reply
Now the one that sits above the seats the integrated bow sack may work.
Old     (bremsen)      Join Date: Aug 2005       05-30-2007, 4:27 PM Reply
pics....please!
Old     (ryan27r)      Join Date: Oct 2006       05-30-2007, 4:30 PM Reply
I will try to get some the next time we are out.
Old     (tyler97217)      Join Date: Aug 2004       05-31-2007, 6:21 AM Reply
I am running the GG bag (1150 lb) in the front locker and then the 650 lb bag in each of the back compartments. I have found that filling the front one full and then the rear bags only 2/3 full produces the best wake. Wake plate around the middle. Very consistent, hard and clean. When we fill the rears we start having problems keeping consistent and then typically keep the wake plate down. The wake must be huge the way you are running. Is it staying consistent?
Old     (dicky_diehl)      Join Date: May 2007       05-31-2007, 9:37 AM Reply
hey diggs love the black tower i was going to do that to mine but thought it might be to much black.i was wrong looks sweet! sounds like you are running the same weight ratio i am 50/50 i like a steeper wake so i run the plate 100-75% up.it stays consistent with a little lip on top for some extra pop.do you think that the integrated bow sack would fit under the front seats i would like to plumb one in but don't know how much weight i would get out of one.
Old     (schmo)      Join Date: Oct 2003       05-31-2007, 10:12 AM Reply
I would be interested in the wake descriptions as well as pictures. What does it compare to like this... what is the size, shape, etc?
I have a 24SSV with the 1200lb bag up front... two 800 or so in the rears and about 300 of lead up front. I like the wake as it has a nice transition with a little lip to pop you up at the top.
I am considering the 22SSV for later this year or next year if it gives a comparable (or better wake) with the same or less weighting.
Old     (dicky_diehl)      Join Date: May 2007       05-31-2007, 10:35 AM Reply
dave i demoed 2 24ssv's last year and 1 22ssv both had stock ballest.i thought the 24 had a longer transition and looked bigger from the boat but i thought that the wake was too narrow i keep going out instead of up.the 22 reminded me more of my old mobius and my buddies 05 x-star fully weighted that i rode behind all last year becuase i sold my mobius at the begining of the year.the wider the wake the shorter the rope the bigger the wake thats just my opinion.
Old     (pdxviperguy)      Join Date: Jul 2006       05-31-2007, 11:04 AM Reply
I have an 07 22 and that wake is dialed. I am running the 1150# GG sack up front with the 400# bags in the back. I run my wakeplate about 50% like the stock setting but tweaked it up a little bit last night to about 75% and it seemed to make it a bit lippier. I opted not to go for the larger rear bags as I don't want to have to monitor where they are as far as filling goes.
Old     (dicky_diehl)      Join Date: May 2007       05-31-2007, 11:15 AM Reply
bryan i have the 750's in the back and they fill all the way up with no problems just wait for the water to come out of the overflow and your full.hey do you have your 1200# bag slide all the way up or back becuase if its back the hatch door pops up.how much weight do you think the bag really gets in it becuase you can't fill it all the way up.i think maybe 1000#
Old     (deltariderscom)      Join Date: May 2007       05-31-2007, 11:21 AM Reply
Here is the 22 with 2600 lb total ballast weight and 6 guys. Riding at 80 + feet at about 26.
photo by WCW
Old     (dicky_diehl)      Join Date: May 2007       05-31-2007, 7:11 PM Reply
26 sounds fast did you gps your speedo.
Old     (tyler97217)      Join Date: Aug 2004       05-31-2007, 10:48 PM Reply
we run 24+ and it is gps'd... and you know the dra guys know what they are doing... to ride at 80' he is probably spot on....
Old     (acurtis_ttu)      Join Date: May 2004       06-01-2007, 5:40 AM Reply
We're running @ 23.5 GPS'd with just stock ballast and 4-6 people in the boat.
Old     (smewth001)      Join Date: Oct 2004       06-02-2007, 10:44 PM Reply
Hey Dicky why don't we try that baby out? I pulled you all last year why don't you repay the favor! I just gave you 210 lbs of lead. Buy the way you should of went with the black tower. But either way your boat and truck combo is one of the best I've seen by far.
Old     (dicky_diehl)      Join Date: May 2007       06-03-2007, 12:37 PM Reply
word smooth-1 i just got done putting some lead in the front.tight squeeze! you can have 1st ups on tuesday if it ever stops raining!
Old     (kylek306)      Join Date: Feb 2003       06-03-2007, 4:41 PM Reply
we run between 25 and 26 too, about 80'
