06-12-2007, 8:28 AM
what is the best stuff to use that isn't hard on the bindings??
06-12-2007, 8:30 AM
newt juice
06-12-2007, 8:45 AM
KY Jelly
06-12-2007, 8:58 AM
if you're not going to keep the same bindings for 5 years (which most people won't), i wouldn't worry about anything being "hard" on bindings. we use $0.69 shaving cream all the time and it's never broken down a binding...plus, i think it's slicker than lube...it's definitely cheaper...and rinses just as quick.
06-12-2007, 9:18 AM
Colgate foam!!
06-12-2007, 9:31 AM
Hinge-Tech...
06-12-2007, 10:55 AM
Not this again
06-12-2007, 11:14 AM
Newt Juice. If not, just make sure your using something environmentally friendly.
06-12-2007, 11:15 AM
Newt Juice is environmentally friendly. Not sure how much you care about fish or the eco-system, but putting soap into lakes is apparently bad stuff. Byrd is right on, though.... Go hingetech and you'll never need slime again.
06-12-2007, 11:21 AM
Ill second Byrd! Hinge tech is the only way to fly
06-12-2007, 11:29 AM
I lube my hinges with Newt Juice to keep them working properly.
06-12-2007, 11:41 AM
^^^ Funny, your profile says you own Murray's... Hinge tech is the bomb and only way to go.
06-12-2007, 12:06 PM
tuff to do when I just bought some 06 transits,
06-12-2007, 12:14 PM
Amsoil 15w40 Synthetic. Good enough for the truck, good enough for the bindings.
06-12-2007, 12:26 PM
So do you lube them every 3,000 runs or what?
06-12-2007, 12:35 PM
^^^ Do an oil analysis usually go about 10-15K
Nope, not yet.
06-12-2007, 12:40 PM
I'm amazed it took a whole 2 people to respond before we got KY.
Cheap soap 50-50 mix...safe for the enviroment and your feet smell great.
06-12-2007, 12:41 PM
babes binding butter
06-12-2007, 6:09 PM
A full spray bottle of water with a dash of Palmolive Dish Soap..."you're soaking in it!"
06-12-2007, 10:03 PM
spit
06-12-2007, 10:08 PM
hinge tech..... I just got stitches in my heel and was able to ride the tournament next day and clinic in 2 days.....easy on for sure.
06-12-2007, 11:13 PM
NEWT JUICE
06-12-2007, 11:22 PM
Soap.
06-12-2007, 11:31 PM
i am using newt in a pump
06-13-2007, 12:11 AM
KY, no way man, astro-gluide is the bomb, it makes your feet tingle just kidding, knewt juice all the way it wont eat up your bindings and its safe for the fishies.
06-13-2007, 8:36 AM
Pencil Shavings, all the way!!
06-13-2007, 10:37 AM
Moose Juice, It is the only stuff that I can pick up easy. There is duck butter also, but I think having it in spray form will make it last longer. The duck butter is in a squeeze bottle which I think I would tend to use too much with each use.
06-13-2007, 12:17 PM
Moose Juice.
06-13-2007, 12:22 PM
soap.
06-13-2007, 12:30 PM
Water-down dish soap if I use anything at all.
06-13-2007, 1:05 PM
does ky jelly really work??
06-13-2007, 1:16 PM
haha, if ky can slide a sausage link between roast beef curtains im sure it can get a foot into some rubber boots..
06-13-2007, 1:19 PM
If you need lube, try some other bindings. Nothing worse than having to get on the back of the boat to put your boots back on with lube. CWB Fuse = no lube
06-13-2007, 1:50 PM
only reason I'm using lube is to get my new transits broke in, becuase the are tight right now
06-13-2007, 2:35 PM
3DS, hard bindings to get into...Great bindings to ride. It's worth the extra effort IMO.
06-13-2007, 3:23 PM
I'm all about the Newt Juice. And, the Newt Juice squiter. We mount it in one of the rear storage compartments and let the hose hang out the back. It makes it nice and easy.
06-13-2007, 3:30 PM
Faction bindings... they open wider than a homosexual's... well... they are easy to get into and out of.
