The "Dolefin" is hydrofoil designed to provide upward lift to the rear end of your boat. This is especially helpful for underpowered boats pulling skiers out of the water. I had one on my old I/O it reduced bow rise, and helped get the boat on plane more quickly. Malibu offers the “Wedge” on their inboards. The Wedge is also a hydrofoil, but it provides a downward lift, I think that I’ve read that the Wedge has the same effect as adding 1000 pounds of ballast. The Dolefin would work against a Wedge, so if you were to find a wedge for an outboard it would counteract the Dolefin. DISCLAIMER – Don’t blame me if you attempt the following and SINK YOUR BOAT, cause injury or other damage. If you were to install a Dolefin upside down it seems like it would provide the effect that you want BUT BE VERY CAREFUL. I’m sure that Malibu put a lot of effort, engineering, and testing in to the development of the wedge. The Dolefin is designed to provide a lot of lift at slow speeds. Installed UPSIDE DOWN it just might SINK YOUR BOAT. I don’t think that the Wakezup can be installed on an I/O or outboard. The text in the link discusses replacing the ruder with the Wakezup hydrofoil. I assume that they mean inboard rudders.
