Hi,
- Have attached a few pictures which show the wiring on the isolator on my Sanger. I figure there must be a better way to do things and im interested in how others have done it.
Running a single isolator with two batteries, the isolator running directly into the amp rack (3 amps) with the ballast pump power running off there also.
Id be keen for any advice.
- Second issue is my sub box. The Sanger floor is raised in the corner and ive struggled to try and make the box 100% level. Ideally id like to have it raised off the ground so i can put my feet underneath it.
Any ideas or tips on how to make some mounts to level the box? Pictures are of the box and the mounting plate, which will be getting modified to fit a heater.
