Bigger is not always better when it comes to boards. Because of my job, I ride a lot of different boards in a lot of different sizes. I always hear "bigger boards land softer" but between sizes of the same board I can hardly tell the difference. As Pierce said - your technique plays the biggst factor, especially on the same model board. From my experience, when a board starts to get too big, it's not usually the swing weight that tells you its too big - it's that it's harder to set a good edge on your cut to the wake, the surface area makes it harder to ollie, choppy water makes you skip across the water, etc. From my experience, 180 lbs is probably pushing the lower weight limit on the Natural 144 - the board is wide & the tips are really wide as well. But - as has been said - if it feels right - stay with it! (Message edited by team_o on May 16, 2007)
