Old     (ship_of_fools)      Join Date: Sep 2007       03-22-2010, 7:18 PM Reply
I have a Clarion EQS746 EQ and I am happy with it.
It seems to work just like it should but when the tunes are really cranking (particulary the sub) the lights on it will dim and flash a little bit.
I have tried a heavier power wire but it didn't seem to make a whole lot of difference.
Just curious if this is normal.
Thanks
Old     (acurtis_ttu)      Join Date: May 2004       03-23-2010, 6:49 AM Reply
Not a power issue, usually a better ground will help.
On big bass hits your probably going to get some dimming of the display. Mine always did.
If it really bothers you, you coudl try adding a small cap ( radio shack) on the pwer/ground feeding the EQ.
Old     (ship_of_fools)      Join Date: Sep 2007       03-23-2010, 4:28 PM Reply
I'll try grounding it better and see what that does.
I already have a cap on it.
It isn't a big deal, probably a lot less noticeable once I get it outside and in the sun. Right now it is just in the garage.
I was just curious if this is normal or if I really had a wiring issue.
