UpNorth, there are two ways to pump. The first and, propably most recognizable is, to pump the nose, where you'll lift your front foot up allowing the nose to rise (a little) and then push back down. That motion, repeated, will cause the board to gain speed. The second method of pumping is to combine quick turns, left and right, and that will also cause the board to gain speed, these turns are small and very rapid.
