Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through March 18, 2009
Old     (cweed)      Join Date: Sep 2008       03-15-2009, 4:32 PM Reply
In the user manual for the XS-12 it has plans for a tube port. I'm looking at building a slot ported box for an XS-12 and was wondering if anyone else had built one and what the dimensions were for the box/slot?
Old     (05mobiuslsv)      Join Date: Apr 2006       03-15-2009, 7:23 PM Reply
Corey why are you set on a slot port. Round ports properly tuned sound better than slot ports 9.5 times out of 10, especially if you use a round port with flared ends.
Old     (jonyb)      Join Date: Nov 2008       03-15-2009, 7:50 PM Reply
Either use the 3" tube port they recommend or call John Gyver at WS and ask him. Justin (tier 1 customer service guy) told me to call him before changing their enclosure plans. I'd do that if I were you.
We built a tube-ported box for an XS12 last week and it sounds awesome with channel 5-6 mono of the SYN6 powering it.
I've got a picture of the XS12 box if you want to see it.
Old     (cweed)      Join Date: Sep 2008       03-15-2009, 8:57 PM Reply
Not really set on anything, have just built slotted port boxes in the past and like the structure/look of them. If the consensus is tubed, then tubed is what will be built
Old     (david_e_m)      Join Date: Jul 2008       03-16-2009, 10:14 AM Reply
Corey,
Pie times the radius squared. So your 3-inch round port should be seven square inches (1" X 7" or 2" X 3 1/2", etc.)
The port length and surface area determine the resistance which combines with the box internal compliance and woofer parameters to arrive at a tuned frequency. As long as you don't alter these ratios, the shape of the port will have little impact.
David
Earmark Marine
