What kind of CD's are you tryign ot play are they burned cd's? Do you get an error message on the radio screen? Does the screen show the CD spinnign and you get no sound? or do you get nothing when you put in the CD. Your dash voltage is usually wrong, dont; go by that. hook up a voltmeter. You cd player will play down to probably 11 volts or so. (your battery will be very dead at this point) You'll only see clsoe to 14 when the boat is running. Sounds like an issue with the radio, if it turns on, you have enough power for it to spin a CD. What does seems okay mean???? does that mean you tested the alt and yoru seeing 14.4 volts and a low current draw?
