Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through June 18, 2006
Old     (wakebud3389)      Join Date: Oct 2005       05-12-2006, 9:02 PM Reply
Is there a way to remove unwanted stickers from your board?
Old     (wake_upppp)      Join Date: Nov 2003       05-12-2006, 9:12 PM Reply
Try a hair dryer or heat gun set on low. Any glue residue will come off with naptha/lighter fluid.
Old     (aidan)      Join Date: Feb 2004       05-12-2006, 9:47 PM Reply
Heat and lift-off ( homedepot )
Old     (wkbrdr)      Join Date: Jan 2006       05-13-2006, 6:11 AM Reply
razr blade...
Old     (regalado1)      Join Date: Dec 2005       05-13-2006, 8:55 AM Reply
Be careful with the heat gun. They get real hot real fast.
Old     (gtaussie15)      Join Date: Apr 2005       05-13-2006, 8:58 AM Reply
WD40 trust me, works like a charm, then you just rub them off.
Old    big_images            05-21-2006, 6:26 PM Reply
You can get a product called Rapid Remover from most sign shops.. Although I've never used WD40 it makes since that it would work. But Rapid Remover is made to remove vinyl stickers.
Old     (actiondcpd)      Join Date: Apr 2003       05-21-2006, 7:14 PM Reply
Will WD40 work on a car window? I have a sticker on there I can't get off!
Old     (thane_dogg)      Join Date: Jun 2002       05-21-2006, 7:33 PM Reply
actioncpd - yes. WD40 works pretty well. You can also use goofoff, which is basically high powered WD40.
Old     (pittsy)      Join Date: Apr 2004       05-21-2006, 7:42 PM Reply
razor blade and goo gone
Old     (janzy)      Join Date: Aug 2004       05-22-2006, 12:01 AM Reply
WD-40 works well, but you can also try peanut butter. Yes, I know it sounds weird, but the oil in the peanut butter actually dissolves the glue and makes removal easy. It's more eco-friendly, but you have to let it rest for a while tough.
Old     (kristian)      Join Date: Nov 2002       05-22-2006, 1:01 AM Reply
WD40, nail varnish remover, wood varnish remover. I bet methilated spirits might work, not sure never tried it.
Old     (rnopr8)      Join Date: Apr 2005       05-22-2006, 5:25 AM Reply
goo gone
Old     (seadawg)      Join Date: Jan 2006       05-22-2006, 1:57 PM Reply
Goo Gone is amazing stuff.
Old     (neffro)      Join Date: Jul 2005       05-22-2006, 2:48 PM Reply
soak with windex, works like a charm!!!!
Old     (aden_g)      Join Date: Mar 2006       05-22-2006, 2:54 PM Reply
i use razor blade with windex/water to get it off. if there is any glue left on the board use goo gone or canola/vegetable oil.
Old     (colorider)      Join Date: Jun 2001       05-22-2006, 10:03 PM Reply
One of the best things is plain mineral oil Even vegetable oil works wonders. And wont harm any finishes
