Old     (mikerod29)      Join Date: Dec 2002       09-11-2007, 10:13 AM Reply
Hey all what is your normal operating temp, no problems with the boat but just wondering what I should look for. Its a 335 monsoon in a Malibu VLX
Old     (larrys)      Join Date: Jun 2005       09-11-2007, 10:16 AM Reply
160
Old     (auto)      Join Date: Aug 2002       09-11-2007, 10:39 AM Reply
160 hardly ever changes.
Old     (04outback)      Join Date: Jul 2007       09-11-2007, 6:36 PM Reply
Indmar Assualt 350 EFI / 325 hp.. runs around 175
Old     (westsiderippa)      Join Date: Dec 2006       09-11-2007, 6:58 PM Reply
160 on the money all day long.
Old     (midlifecrisis)      Join Date: Feb 2007       09-12-2007, 12:22 PM Reply
Black Scorpion 330 hp - 175
Old     (ottog1979)      Join Date: Apr 2007       09-12-2007, 12:24 PM Reply
2002 Mercruiser 350 Mag - 160, never varies
Old     (swoop)      Join Date: Jun 2006       09-12-2007, 1:11 PM Reply
163-digital
Old     (mikerod29)      Join Date: Dec 2002       09-12-2007, 1:25 PM Reply
Thanks guys!
Old     (mlb75)      Join Date: Aug 2007       10-15-2007, 4:50 AM Reply
ZR6 175 all day, love that closed cooling...
Old     (lovin_the_wake)      Join Date: Jul 2007       10-15-2007, 7:37 AM Reply
mine sits between 160 and 165 at idle but gets up to 190 while driving
Old     (rallyart)      Join Date: Nov 2006       10-15-2007, 8:04 AM Reply
Montgomery, your temp should not get up to 190 unless you have a closed cooling system with antifreeze and a pressurized cap. You may not have enough water flow and a slipping belt or more likely a damaged imperllor
Old     (05mobiuslsv)      Join Date: Apr 2006       10-15-2007, 8:12 AM Reply
160 cruising or idling doesen't matter.
Old     (lovin_the_wake)      Join Date: Jul 2007       10-15-2007, 8:51 AM Reply
damnit I need to get that fixed asap huh
Old     (denverd1)      Join Date: May 2004 Location: Tyler       10-15-2007, 9:16 AM Reply
^ yup. I changed mine out a few months ago b/c i didn't do it at beg of season. Worst looking one to date. Definitely will be replaced before we start hitting it hard next year.
Old     (lovin_the_wake)      Join Date: Jul 2007       10-15-2007, 9:26 AM Reply
I guess I know what my weekend project is going to be
Old     (heem)      Join Date: Dec 2005       10-15-2007, 11:58 AM Reply
170-180 depending on water temp
Old     (waterfreak)      Join Date: Jul 2007       10-15-2007, 12:15 PM Reply
160 always never changes.
Old     (etakk7)      Join Date: Apr 2006       10-15-2007, 3:29 PM Reply
160
170 if I'm running the heater
Old     (2007_x2)      Join Date: May 2007       10-15-2007, 3:55 PM Reply
07 MCX 350 with Catalytic Converters sits at 160
Old     (deltaboy)      Join Date: Jan 2007       10-15-2007, 7:10 PM Reply
PCM ZR6 in my Wakecraft and never moves from 160
Old     (ally505)      Join Date: Jan 2003       10-17-2007, 7:41 AM Reply
was 160, then installed a heater, now 140. Going to change to a hotter stat next spring to get it back up to around 160.
Old     (rallyart)      Join Date: Nov 2006       10-17-2007, 8:02 AM Reply
Al, the thermostat should be automatic, if it's working correctly. If it changed after installing the heater that's a bit weird.
Putting in a higher temp thermostat might make the air coming out of the heater a little warmer but you'll have some risks with localized boiling in the engine if it's not closed cooling.
