Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through June 07, 2004
Old     (flashalexb)      Join Date: May 2004       05-27-2004, 12:04 PM Reply
How do you have ur bindings set up. Mine is all the way out on the front binding and slightly duck foot and I have the back binding one in and just set up straight.
Old     (thane_dogg)      Join Date: Jun 2002       05-27-2004, 1:38 PM Reply
WHAT?!
Why do you have your boots set up like that?
You want to ride more on the front of the board? I've never heard of that before?
I've got both feet all the way out with about 10-12 degrees of duck.
Old    gaboarder            05-27-2004, 1:40 PM Reply
One screw from all the way in, turned out equally on each foot. Check this thread out
http://www.wakeworld.com/MB/Discus/messages/1/168120.html
Old     (rock_n_boardin)      Join Date: May 2003       05-27-2004, 1:45 PM Reply
My stance is the same as Thane's.
In surfing it's called Pearling, nose first into water, you go head first over the nose. You are set-up to do the same thing on a wakeboard with that stance. If you are going to vary the distance from front and back. Then you definetely want to have more weight towards the back of the board.
As far as ducking out or not, your angles of your feet are pretty common. Ducked in front, straight or straighter in the back. But I prefer to duck them the same amount. Especially since I'm trying to perfect my switch riding.
