Correct on the ATF. I'd go ahead and check the level first to make sure. If you have a v-drive, you should see the pump in the engine compartment. If a direct drive, you will need to take out your rear storage panels, usually on the starboard side. If the fluid level is correct, I'd try the plate with the engine running before I did anything else.
