Old     (waketowake)      Join Date: Jul 2007       09-05-2010, 6:36 AM Reply
So the other day i was moving the wires around to make my set up look a little cleaner, and my sup started to make the sputtering sound. You can still here the bass theres just a sputter with it. I moved the wires back to normal, and it still made the sound. The set up is a JL audio M10IB5 CG WH 10" powered by a memphis 1600 its 250w at 4 ohms, and thats what i have it set at... so hopefully its not blown.
Old     (david_e_m)      Join Date: Jul 2008       09-05-2010, 7:05 AM Reply
There are two connections on any woofer where it can play intermittently at a high rate. One is the terminal post to braided wire and the other is the braided wire to voice coil connection. While the woofer is playing carefully restrict its motion by appling pressure to the cone with your hand. If the noise stops because the woofer is now playng continuously without interruption then you can be relatively certain that the issue is one of these points. If it remains then start looking elsewhere. Thats the best I can do from your description.
David
Earmark Marine
Old     (882001)      Join Date: Nov 2003       09-05-2010, 8:23 AM Reply
does the cone move freely? or is it scratchy?
Old     (waketowake)      Join Date: Jul 2007       09-05-2010, 9:23 AM Reply
yeas the cone is moving, and it is kinda scratchy.
Old     (david_e_m)      Join Date: Jul 2008       09-05-2010, 10:52 AM Reply
If its scratchy then another test is without the woofer playing carefully push in on the cone and listen/feel for the voice coil rubbing in the motor gap. This would be an indication of a burnt voice coil or a bent former in some speakers. You have to do this in a balanced and centered manner so that your action is not actually the cause of the contact as there is already a minimal tolerance.
David
Earmark Marine
