It's not electricity in the boat that's the problem it's galvanic corrosion that might affect the pylon. That's dissimilar metals that can make a mild battery, like steel and aluminium. Is you pylon plated steel and the plating is flaking, or is it aluminium and it has flaking? Under the flakes is it rust colored or aluminum colored, or are the bolts holding it flaking?
