Old     (dizzyj)      Join Date: Jul 2003       08-04-2009, 9:25 PM Reply
got my 3s pretty consistant. riding away from 3 out of 4 or so.
whats next? switch bs so I can 180 back and forth?
Old    surfdad            08-05-2009, 4:11 AM Reply
You haven't finished your 3's yet! :-) Carve your three's not using a hand. Ollie oop three (I don't consider these separate tricks - but add the three grabs up at the nose with your leading hand), stall your three at 180 and glide backwards a second or two and finally a bottom turn into a carving three. THEN do all those backside switch. :-)
Old     (ragboy)      Join Date: Aug 2007       08-05-2009, 8:14 AM Reply
I have 2 trick videos I am just finishing that I did with Sean Cummings. One is for a backside 180 to switch, and the other is the 180 shuvit. The first is very easy to practice and learn, the shuvit is more difficult. Even when you practice the shuvit with the rope, you still crash, crash, crash. Which also makes it that much more rewarding to land.
