Anyone else have this problem. I have a 05 Mobius Lsv. Using fly high 750 rear bags. I used lock tite on the fittings that go into the bags, used SS hose clamps for the fill and drain line that connect to the quick disconnect fittings. I made sure that the fittings that screw into the bags had both rubber o rings on them. Its almost like the quick disconnects leak, or the bag leaks where the threaded hole is. Anyone else have this problem. Unless i am just sitting the boat so much when we surf i taking in water over the sides
