Take the advice of ACME or OJ props. Tell them what you are trying to do with that boat, which BTW is most likely propped to pull slalom. The first # is diameter, the second # is pitch. For more out-of-the-hole performance you want a lower number pitch. This will RAISE your RPM, not lower it. Careful not to over-rev your engine when you're wide open. So far, seems like ACME is right-on with their advise. Sometimes they will take a prop back if it's the wrong size and you only used it briefly.
