Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through April 09, 2007
Old     (kevin_lsv23)      Join Date: Oct 2006       03-12-2007, 9:32 AM Reply
What is the easy way to dim the dash lights on a 2007 Malibu?
Old     (dbjts)      Join Date: Nov 2003       03-12-2007, 10:29 AM Reply
Plug an electric fire in the cigarette lighter that ought to do it!
Seriously though lower wattage lamps for a permanent job or fit a dimmer switch on the feed to the lights
Old     (mikeski)      Join Date: Aug 2003       03-12-2007, 7:05 PM Reply
You can add a resistor to suit your needs, maybe a bypass switch too so you can switch between high and low dash illumination levels. Probably want to use a good 25watt resistor, maybe 5 or 10 ohms. Radio Shack should have them. Make sure it doesn't get too hot and don't place it next to something that melts easily.
(Message edited by mikeski on March 12, 2007)
Old     (kevin_lsv23)      Join Date: Oct 2006       03-15-2007, 1:23 PM Reply
Thank you, Mike.
