Just a venting post. Went to Oroville on Thurs night to grab a boat-in campsite. Launched boat at 930pm. 20 min later started overheating. After inspection, found I wasn't getting water, of course. Took water pump apart, completely disintegrated impeller. After closer inspection, actually cracked pump housing. Dead in the water. Limped back to ramp, but it was closed down due to houseboat launching that punctured its fuel tank. Had to get towed to another ramp to get boat out. Made 2 hour drive to get home at 0330. Replaced pump/impeller Friday then went back to lake. Weather was chilly most of the weekend but ok. On Saturday, hit a log while boarding. Slight vibration, not bad though. Sunday, hit another log, much worse this time. Couldn't go over 5mph without shaking the boat apart. This happened about 5 mi from campsite. Limped back. Pulled boat out Sun afternoon and found one blade bent 90 degrees forward, and one bent 90 degrees rearward. I couldn't believe how much debris was in lake Oroville...I most likely won't ever go back because of this experience although the area is awesome.
