Old     (dizzlestoy)      Join Date: Aug 2006       03-21-2011, 12:05 PM Reply
The adjustment thing on my PB Floyds rattles really bad. But only on 1. Anybody else come across this. Does it suppose to be this way?
Old     (sidekicknicholas)      Join Date: Mar 2007       03-21-2011, 12:39 PM Reply
If you pop the boot off can you screw it tighter/looser?
Mine have some play but not enough to rattle
Old     (dizzlestoy)      Join Date: Aug 2006       03-21-2011, 1:24 PM Reply
Thanks for the reply Nick. I don't think that would fix the problem. The actual lever is free floating. The lever still works it purpose just almost like the rivets are loose or too small. Is that picky of me to get slingshot to replace?
Old     (dubrider12)      Join Date: Jun 2007       03-21-2011, 1:49 PM Reply
try twisting the binding back and forth. Sometimes that latch does not set in the hole when you twist it to set the angle. If you twist it back and forth it will allow it to set and make that latch a little tighter. That has been the case every time i have seen it. Hopefully it is the same for you.
Old     (lseghatch)      Join Date: Aug 2005       03-21-2011, 2:27 PM Reply
What Geoffrey said. Had the same problem on just one of my plates too, works fine.
Old     (seth)      Join Date: Sep 2002       03-21-2011, 3:10 PM Reply
It sounds like the pin is not fully engaged. Wiggle the boot around and it should pop in and be good.
computer wasnt refreshed. What those dudes said^^^^^
