Old     (mrm2083)      Join Date: Nov 2005       08-27-2007, 11:08 AM Reply
My boats voltage low alarm keeps going off. Normally on idle when I have the engine on the volt meter reads 13 volts and when i give it throttle it reads like 14. Now its at like 11 at idle and 12 at wot. Is this the alternator? Also Where can I buy a replacement alternator and can i install it myself? Are there any alternators designed for saltwater? My boat is a mastercraft with the indmar rtp-1
Old     (acurtis_ttu)      Join Date: May 2004       08-27-2007, 11:23 AM Reply
Have you tested your battery to make sure it is not the culprit?
Old     (mrm2083)      Join Date: Nov 2005       08-27-2007, 12:39 PM Reply
wat do i do to test the battery?
Old     (acurtis_ttu)      Join Date: May 2004       08-27-2007, 12:46 PM Reply
remove it and have it tested at your auto parts store, or take your boat up there. You can buy a handheld load tester too.
This is the easiest way.
Old     (rodmcinnis)      Join Date: Sep 2002       08-27-2007, 10:21 PM Reply
It wouldn't be the battery. Sounds like a bad alternator to me.
Rod
