yea...try to find where it's coming from. i had a '98 sunsetter that started leaking in 2002 where the prop shaft exited the hull. my packing started leaking quite a bit also....more than it should have.....but that only happened when prop was turning I think. anyway, fittings comes loose, seals get dried out....shouldn't be a big deal. just try to isolate the leak and you're done.
