Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through November 04, 2009
Old    murphy8166            10-23-2009, 8:05 PM Reply
I have posted 3 pics. Once is of the area where the amp panel is going to be mounted. This is the back area where you see the two larger screws and washers. The amp panel will be mounted to this wall.
The other two pictures are the two ways I am thinking about configuring the amps. Either way the amps will be thru botled and have some stand-offs so that wires can go under amps.
Amps are all Arc Audio KS and the shrouds are being removed and sent to sandblaster & powdercoater. Probably going with flat black> Amp panel will be epoxy coated and covered in marine grade carpet. All hardware will be stainless.
Which setup do you like?
Old     (highrock)      Join Date: Apr 2008       10-23-2009, 9:18 PM Reply
staggered...what kind of boat are they going in
Old     (99_slaunch)      Join Date: Oct 2005       10-23-2009, 10:15 PM Reply
staggered looks good.
Old     (2006maliblue)      Join Date: Mar 2009       10-23-2009, 10:30 PM Reply
^^^x3 staggered fits the panel the best!
Old    murphy8166            10-24-2009, 7:02 AM Reply
MALIBU Sunsetter
Old     (reachjims)      Join Date: Aug 2007       10-24-2009, 8:06 PM Reply
staggered,
nice granite baller!!!!
Old     (andrewjet)      Join Date: Jan 2003       10-25-2009, 8:42 PM Reply
Staggered!! Oh..and thats Baltic Brown granite. LOL Jet
Old     (wake1823)      Join Date: Dec 2005       10-26-2009, 10:07 AM Reply
staggered is the only way to go. Both options aer less than ideal for cooling, the other way will cause alot of thermal protection shutdowns on yoru amps. Remember heat rises.
Old    murphy8166            10-26-2009, 10:28 AM Reply
These amps don't overheat and I have put them through the hot texas summers last year in a stacked configuration. You can hold your hand up against the amps and it will not burn you.
They are also set up differently. Heat sinks are on the bottom of the amp and each amp has an internal fan pulling air in and pushing it out via two different vent configs.
I am going staggered. Got the board cut and the holes all drilled and everything lined up perfect. Next step is to epoxy resin coat and to carpet over the weekend.
I am going to post a new thread with the progress.
Old     (andrewjet)      Join Date: Jan 2003       10-26-2009, 12:08 PM Reply
Hey Murphy. You can also purchase a solar RV fridge cooling fan for like $39 to suck the hot air out of the storage locker to. The solar panel is like 3"x3" if you have a place to mount it? jet
Old     (jayson)      Join Date: Apr 2002       10-26-2009, 2:06 PM Reply
I know its a little late, but here is a pic of the setup in my Malibu.
Old    murphy8166            10-27-2009, 8:30 AM Reply
Nope not too late. How are you doing? Are you living in Waco?
I will post up some pics when I get this project completed. I am going staggered since may amps are all the same size.
I actually have a 1000.1 sitting in the garage which I need to sell.
Old    murphy8166            10-27-2009, 8:32 AM Reply
Old     (jayson)      Join Date: Apr 2002       10-27-2009, 7:55 PM Reply
Murphy...Still here in Waco and doing well. Post up some pics of the project when you get finished.
Old    murphy8166            10-28-2009, 7:03 AM Reply
Good to hear. I will post up some pics.
