Old    kmc            03-13-2003, 12:55 PM Reply
Sorry for the title, but I didn't know what else to call it. I guess I have what I think is a really stupid question but since I don't know the answer, I have to ask it. OK, look at the picture below.
This is an example of what I would call a portable ballast pump. Now the "stupid" question.
Since these pumps (rule, Atwood, etc.) are not reversible & they don't appear to be set up to swap the hose from the "in" side to the "out" side, are you supposed to lean over the side of your boat & only submerge the 2" long nipple on the "in" side to pump the water or are these pumps designed so you can submerge the entire pump in the water? Does this make any sense?
pump
Old     (liveoz)      Join Date: May 2002       03-13-2003, 3:57 PM Reply
Ken,
You just toss the whole pump in the water. If you want to save a little time you can buy another fitting for the other end of the pump, this way you won't have to change it each time you fill and drain.
Old    kmc            03-13-2003, 9:47 PM Reply
Troy, does this mean that the electrical connection & motor are water tight? I would most likely add hose to both ends as you suggest but I was curious because the pumps don't come that way. Thanks for the help.
Old     (liveoz)      Join Date: May 2002       03-13-2003, 10:04 PM Reply
Ken,
Yes it is all water tight in there (as far as I know) I have three Rule pumps and I have been throwing them over the side for three years now, never had a problem. Btw, you don't need a hose at the intake, you can just thread the blue filler adapter right to the pump. The pump works best when submerged, it would be very difficult to prime if you attached a hose and stuck just the hose in the water.
Old    kmc            03-13-2003, 10:14 PM Reply
Thanks Troy. I have an Attwood pump. Do you think this would be the same? Just dunk & pump??
Old     (sandbag)      Join Date: May 2002       03-14-2003, 6:21 AM Reply
Dunk and pump! Perfect!!
Bwahahahahahaha!
