Make sure you're not spinning off of the wake. Get plenty of pop off the wake and then, when you are in the air, use the handle to initiate your spin by bringing it to your rear hip. The handle is the key to this trick not the rotation. If you pull and pass the handle correctly (and look over your rear shoulder) you will get the rotation fine. Good luck!
